If this was something you had done then maybe you could infill the bottom to make it larger than the top and even some beading, as this is the chippy's cock up then it is not your problem to resolve.
I would say you could be right except in the second sentence the OP said "doors". That implies to me that there were several all installed incorrectly. When you "cocked up something" did you do it over and over?oh lah lah, everyone is "so clever" here, as if they never cocked nothing up... I have!
I wouldn't have just left it as is, would've told him (you, the client) to get another door and would've put it right.
Be in a rush- even worse "poop happens"... only few months ago, I've cut kitchen worktop exactly 1 meter short... wasn't cheap mistake, never mind needing to go back itself, but after all, I'm not doing things for the rock-bottom price, I can absorb errors
Not an option in a rented house lol (and yes the owners are aware, but the builders of that suburb 'disappeared' and its unlikely anything would come of trying to get it fixed- the door 'opens' so all is good...I have changed at least fifty doors in bathrooms that were almost unusable with the inward opening doors. Simply (not really) take off arcs remove door chop frame. New frame new door new arcs. Only this time opening out....results in a total transformation in use! Takes all day.
But you didn’t argue with the customer - you accepted your mistake and as such the customer didn’t make a fuss either . Had you argued the customer would have most likely insisted on the correct way .. hats off to youI have to confess, that I too have been guilty of hanging doors upside down .Also when , a site-agent, of having a decorator wallpaper a whole room, with the paper up-side -down.
The doors were on a deVOL kitchen that I installed for a customer. They were a pair of double doors that I was simply rehanging in the existing hinge housings. In my own defence, all the stiles and rails were the same width, and all the hinge positions lined up perfectly it was just that the central rail was off-set, so that it could be read as either a 1930's, or a Victorian pattern door. I had gone for the 1930's look .......... WRONG! When the customer pointed out my mistake, I did offer to swap the doors over, but they liked the look.
As for the wallpaper, well, it was in the home of a wallpaper designer and one of his own designs. It contained a small, repeating flower motif on a plain background. It was only when some chairs were delivered, upholstered in a matching fabric, that we realised our mistake - the flowers hung down, not up. The decorator, refused, point-blank, to rehang the room. And when I admitted our mistake to the designer, he thought it was very amusing, and said he would keep it as a feature.
A valuable lesson I learnt from the wallpaper incident, was that you cannot rely on wallpaper coming off the roll in the correct orientation, except for the ready-pasted stuff.![]()
True, though it would only have been a matter of moments to flip them round as they were easily interchangeable.But you didn’t argue with the customer - you accepted your mistake and as such the customer didn’t make a fuss either . Had you argued the customer would have most likely insisted on the correct way .. hats off to you![]()
To be fair, the door situation wasn’t a mistake (in my opinion) as the rails and Hinge placement was same top and bottom. It’s down to whether you like bigger panel at the top or bottom (unless they are supposed to fitted a specific way, I don’t know).I have to confess, that I too have been guilty of hanging doors upside down .Also when , a site-agent, of having a decorator wallpaper a whole room, with the paper up-side -down.
carpenter you sayHello,
Bit of an odd one! We employed a carpenter to fit our doors. Unfortunately I arrived home to realise he'd done so upside down. The door frames are old so the carpenter pared them down bespoke to fit each uneven frame. He also fitted the door knobs, meaning it will be very tricky now to flip them back around. Unfortunately now I've noticed it its hard to unsee, though I appreciate probably not that obvious to most visitors.
Has anyone got any suggestions? I thought about cutting out/extending the panels so they are an even distance from the top and bottom of the door. Does anyone have any ideas? Unfortunately I think starting again with new doors would probably be easiest but would be too expensive right now and also seems a sad waste.
Really disappointed that he overlooked such an important first step...
Link to the doors here: Door Giant Modern Shaker-Style White Primed 2 Panel Internal Door
