Are you kidding? A Stanley 164 is worth a fortune...Jake":2abaetvy said:Doesn't matter either way, does it?
I recently purchased an LV BUS with an extra 50 degree blade to tackle some bubinga. And so far it has done a fantastic job. Pretty much all I ever use my LN LAJ for is shooting so I can easily imagine the LN LAS being about the same. The LV has literally no backlash, and is a little aggresive on adjustments, but I just have to get used to that.Alf":1z49fwo2 said:It's not relevant to this thread any more it seems, but it's worth bearing in mind with low angle smoothers that the LN and LV aren't directly comparable, especially if you're thinking you'll be swapping blades in and out like there's no tomorrow. The LN has the most finicky and irritating adjustment system imaginable so really doesn't lend itself to frequent displays of versatility unless you have the patience of a saint. Not that it's not a nice plane - I use mine on the shooting board all the time - but it is a drawback to it.Jake":1z49fwo2 said:Doesn't matter either way, does it?
Cheers, Alf
JesseM":29ckkg31 said:BTW the 50 degree blade came somewhat off and had to regrind it. This was quite a challenge with the MKII. I finally figured out a way to hold it to keep it from rotating forward.
Yeah this was not at 50 either. I didn't check but would guess 45-48. When I first put it in the MKII I noticed I was getting an uneven bevel, so I took the blade out to check the squareness. It was off a bit so I put it back in and started grinding away. This is O1 BTW. I only ground enough down to where it was straight which was still a lot of work.labuzz":1abfb1cd said:JesseM":1abfb1cd said:BTW the 50 degree blade came somewhat off and had to regrind it. This was quite a challenge with the MKII. I finally figured out a way to hold it to keep it from rotating forward.
Hi Jesse can you elaborate on that? My 50 degrees blade ( on my LAJ veritas but its the same blade if I remenber correctly) was more near 45 and also can you check if the blade is slightly curved?
On the LAJ54 photo it looks like the microbevel is a bit uneven. Did you regrind and if so using what? Thats the same problem I saw on mine and in fact its on the same side.labuzz":21kse31x said:happy to see that its not just me being a complete newbie :roll:
And yes the registration for high angles on the mkII is tricky...Tks for the tip, I will try.
some photos of my blades ( sorry I have no macro lens ):
Not sure what to do with the blades now I have no grinder
I have checked the flatness of the sole of my block plane ( veritas standard )...The sole was a tiny little bit concave on the length! After 10 minutes of scrubing on 120, and 400 he is flat now.
I think your blade like mine is sitting in the jig properly, its just that the initial grind on the blade is off. You will see that uneveness in the bevel until its straightened.labuzz":2gboy8zd said:I am just using a cerax combination waterstone (1000/6000) and the mkII honing guide nothing else on those blades. I have tryed to compensate for the bevel problem (on the LAJ54) with fingers pressure without success.
I think I will try to regrind the skewed blade on a coarse sand paper.
I have just order an eclipse type of honing guide. How the shadow guide looks like?
Alf":1gjzlap5 said:Gentlemen, is it terribly bad form to ask if these unloved bevels actually successfully planed wood? Or didn't you try?
Cheers, Alf
Sorryengineer one":m9h0ud6f said:oh alf you do ask the obvious #-o
paul :wink:
