Unusual Saw - one for Andy.....
merlin
7 Nov 2010
Oxfordshire
A friend of mine challenged me the other day to see if I knew what this is and wondered if any body knew what its for as I've never seen one.
I haven't got a clue.
The main body is cast in a "T" section with what looks like a frame saw blade fitted, the brass tube on the end looks like a bodge so it could accept a wrong size blade.
What do you think?
Merlin
    90.6 KB
    125.4 KB
The really frustrating thing about this question is that I have read about one of these online somewhere, in the last month or so!
Of course, I can't now find where that was, but I'll say if I do find it.
At least that confirms that it's a commercially made tool, not a one-off. The other one had a hacksaw blade in it, which backs up your idea that yours has been altered to take a different blade.
The conclusion about the other one was that it was a hacksaw for restricted spaces. For example, cutting through a rusted nut where other parts of a machine or engine got in the way.
Nice find!
Funnily enough, I thought of making a similar design saw recently, but for woodworking, with a coping saw blade. This is in connection with cutting out an elliptical aperture for a hole in a hollow box (my harp soundbox). Easy enough to drill/jigsaw/padsaw out a rough aperture, but then it would be nice to cut fairly accurately 2 - 3 mm away from the final line, to leave just a small amount for a router trimmer to take out, following a template.
I probably shan't bother though, as I am well on the way to the first one, and if I make any more the holes will be cut while both sides are accessible!
Hello Andy,
I think you may have hit the nail on the head !
I shall see if I can have a closer look at the saw later as there is something stamped on it but its full of paint.
Thanks, Merlin
I've got one similar, I bought 2nd hand in Tasmania a few years ago thinking it would be handy. Like the one in the Proto catalogue it uses a 10" blade. It is unbranded.
I couldn't find a 10" blade anywhere so eventually a jeweller friend cut down a 12" for it.
Cheers,
Geoff.
    310.9 KB
That's also a Proto saw. If you look in the older catalogues, available in the same place as the one I referred to, you should find it.
Thanks Andy, a quick look found it in Catalogue 4820 from 1948 . Listed as No 344 Low Clearance hacksaw. That's a pretty handy site.
Cheers,
Geoff.
