Unusual paint sprayer question
alex robinson
12 Jan 2022
Reading
I am hoping someone on here with knowledge of paint sprayers (and with a good imagination) may be able to help me with an odd request.
I work in a research lab. A colleague who works with microplastics has been suffering from RSI as a result of squeezing a squirty bottle too much when washing beakers and filters. (Cannot use tapwater - everything has to be multiple filtered etc and only pass through bottles / tubing made of glass, metal or PTFE).
We wondered if a paint sprayer linked to an air compressor might be a potentially more suitable way of doing this. Instead of multiple squeezing of the bottle, 1 gentle press on the trigger. A quick test with Screwfix's cheapest air compressor accessory kit suggests that it might be possible. However...
1) Is is possible / practical to get filters for the air supply. We would want a (preferably) glass fibre filter of around 20 microns.
2) What spray gun to get. We want almost the exact opposite of what people usually want. Instead of a fine even dispersion, we would want a relatively concentrated jet. Could this be achieved by blocking the side air nozzles? If would also need to have a very gentle to operate trigger. No idea if trigger pressure is something that people select paint sprayers for!
3) Could the hopper be attached to the side of the cabinet where the work was being done? Most gravity guns I have seen have the hopper fixed to the top of the gun, but I cannot see any reason why this couldn't be attached via a length of PTFE hose? Unlike spraying a car, there is no need to be able to move around.
The other option I have thought of is a peristaltic pump setup, but that feels like a more complex system that would need more building from scratch. Anything involving using air to pressurise a container of water is likely to have a long lag on the system, so cause a lot of dribbles.
Any thoughts or suggestions would be greatly appreciated!
Every cheap set of compressor accessories comes with what is described as a paraffin spray gun. I think that meets the intent of what you describe in terms of jet.
It would appear to work on the principle you say you do not want (air entering and pressurising the vessel displaces the liquid) and would be made of unsuitable material but might give you some ideas.
Another place to look is Gloria sprayers - normally they are the pump up plant sprayer idea, but I think they offer a model that can be pressurised by an external supply (and has a built-in properly tested pressure relief valve so you do not accidently make a bomb. They offer a wide variety of nozzles as well as a wide range of non-metallic materials. They would probably make a custom nozzle for you if you could describe flow rate and pattern to them.
Have a word with your health and safety officer or HR
If the problem is explained see what they can do
Sorry to say this but my CYA (cover your backside) has just kicked in and I can see you personally being held responsible for bad practice / contaminated tests
And all the above as well as your work mate not being able to claim off the firm because you implemented a non approved method
If I am way out of line then
My most humble apploigies.
Could you assess what pressure and flow rate the standard squeezy bottle delivers?
It strikes me that a KISS system, of a gravity-fed spray head with a simple on-off valve could deliver similar performance. It all depends on if the available height will give enough pressure head. Put the tank on the roof and relocate the lab into the basement.
What about a chemical type pressure sprayer, the sort with a handle you pressurise the container with - the expensive ones are stainless steel. Something like this
https://bestsprayers.co.uk/products/dual-stainless
That could be an option. The hose will be a problem however. It will be a standard commonly used plastic so we would have to work out a way of switching it out for PTFE or fitting a 20 micron just before the nozzle. (Working with plastics is a pain!)
It did come with a paraffin gun and that is an option. Certainly didn't dribble! So it doesn't have one of the problems of the DIY option, but it would mean having to carry the water with the gun. Maybe it is just the budget set, but the paraffin gun seemed really unwieldy.
I will have a look at the Gloria sprayers. I am sure there is another group of people with weird requirements about materials for sprayers!
Not out of line at all. I appreciate the sentiment. H&S agree (unsurprisingly) that the old method isn't any good. Working out the new approach is a bit specialised for them however. We will need to run new calibrations and blanks, but we have reasonable freedom to develop new protocols so long as they get the job done. (I will post some pictures of a very fun new technique involving a digger we developed recently once everything is set up)
That is tempting, just to see the look on the facilities guys faces if we suggested that! The volume required isn't huge, but I think it would have to be a 2 story set up to get the pressure needed and realistically that is unlikely.
Interesting question. Having suffered trying to get container 'clean' (your definition) and failing for days,
I can see the sprayer, tubing, compressor having to be investigated / assessed.
You might look to the medical field (or military) for appropriate filters on the output.
As the standard squirt bottle is around 500ml capacity, maybe something like a hospital IV drip bag atop an adjustable pole could suit. Put it between two spring or weight assisted boards or something like a weighted log tongs (https://www.amazon.co.uk/VEVOR-Skidding-Tongs-inch-Claw/dp/B0CDW62Y5X)* so the mechanical squeeze compensates for lack of elevation and still produces the pressure required.
If you produce the pressure by a different means to compressed air, that eliminates all the air filtration requirements. The other option is to have the water in a bladder that is pressurised by the air. Then the air could be as dirty as you like since it never contacts the liquid.
* or mount the drip bag whoopie cushion-style on the chair. Bonus is that you can work when sitting down.
"Clean" is one of those things that entirely depends on what you are concerned about! I am not a plastics person, normally working on pesticides or metals. Both of those are easy - acid washing for metals and organics such as acetone for the pesticides. Even microbial cleanliness for molecular biology isn't really hard.
Plastics work is difficult as 1) It is everywhere, especially in the form of microplastics. One of the projects is measuring the levels in drinking water, so any kind of washing has to be done with liquids that have been multiple filtered. 2) The majority of the items one might want to use to make equipment with are made of plastic. Tubing valves etc all therefore have to be made either of non plastic materials like metal or glass, or out of an obscure and expensive polymer that can be ignored in the subsequent analysis.
