unidentified jaws
Phil Pascoe
29 Jan 2012
Shaft City, Mid Cornish Desert
Any ideas what chuck this jaw would fit? There's no centre line hole for slide fixing.
Pin jaws but not sure what make.
Look closely at the photo, specifically the fixing holes and think about how they could bolt to a master jaw.
The ones pictured are on the same pitch circle.
Every other one you see has holes in line with each other, with the projection of that line intersecting the centre of the chuck.
I remember having something similar on an old craft supplies mini grip chuck. They also made a maxi grip chuck which was a similar design but bigger. What's the outside diameter of the jaws?
Record jaws have a raised tenon to fit a slot in the carrier whilst Axminster jaws are the opposite.
