U channel
SteveF
16 Sep 2013
Maidstone
anyone know where you can buy rubber u channel off the shelf
I would rather drive 20 miles than wait for delivery
I looked at halfords but they only seem to have hard chrome stuff
I thought about ripping some power cable but dont think I will get a straight cut
only need about 12"
Steve
What size channel Steve? I assume you mean similar to motorcycle screen edge trim in size?
Try looking at an electrical wholesaler for grommet strip.
yep that is the stuff
just for a cut out in oil drum lid
Steve
Steve
Is this for your cyclone?
If it is and it is to seal between the cyclone base and the collection bin. Would some silicone applied before screwing / bolting the 2 together work? ;)
it is not to seal
i was going to use a bit of dpm or something ...whatever laying around
i can just see me sticking hand up into cyclone if i need to clear it and blood coming down ruining the sawdust :D
Steve
Ahhh good call. I assume the hole is slightly larger than the outlet hole on the cyclone? If not with the rubber on there it might help cause a blockage/ interrupt the flow of sawdust. ;)
See if any motor factors or body shops near you have any door seals. Should do the job.
Try a scrap yard too
i have been let down with my dust can
can anyone recommend a container for my cyclone?
Steve
Don't large bandsaw blades come with the teeth protected by a plastic U strip anymore, did in my day.
my new bandsaw blades....just arrived from tuffsaws never came with any protection
but i am so looking forward to "mounting" one =P~
Steve
Steve
How about those blue food containers, they are often used. You just need to find a seller near you.
http://www.ebay.co.uk/itm/New-15kgs-Dog ... 4d09918a4a
Other sizes are available. I just searched for plastic drum, food drum, plastic barrel.
Steve
Nice. :)
Steve
Empty 205 litre oil drum? You could probably pick one up for free at a garage or bus depot :)
