Greetings Brothers,
I have recently been in the process of restoring several of my older backsaws.
The one in question here is a generally nice but somewhat neglected TYZACK with a brass back (upper saw in image).
In the process of restoration, I dismantled it, cleaned it up, and reassembled it. As you can see, the saw plate was moderately pitted.
In my experience, one can still produce a usable saw despite the pitting. Not ideal, but still cuts wood reasonably well. When I set the teeth, I follow it with some light stoning, which I believe, along with filing, removes any pitting from the cutting tips.
Sadly, when it came time to sharpening and re-setting the teeth, I found that many of the teeth were snapping at the base, despite only a moderate set.
I did a little research, and found that older saw plates sometimes undergo what is termed "crystallization" of the steel, which makes it brittle and prone to cracking.
So, I was left with little choice but to replace the saw plate.
I had on hand spring steel/shim stock in various thicknesses; 0.020 and 0.032 inches. The steel is somewhat hard, but responded to filing without too much difficulty. I used the latter, thicker steel, but will choose the thinner for most future saw plates.
The original saw plate was 0.027 inches thick. I reasoned that the thicker steel would be less prone to deformation on this unusually deep plate.
So, I traced and cut the new saw plate to match the old one, but left the entire depth of the spring steel (6 inches), having seen some saws with this type of exceptionally deep blade, and wondering if it would be useful/practical in the shop. We will see...
So, I assembled the saw, and cut new teeth using a "graph paper" technique I found recommended on YouTube by Bob Rozaieski ().
I pasted the graph paper on the the saw plate and filed the tooth gullets. When I do this again, I will still use the graph paper technique, but start with a fine-toothed hacksaw blade to form the tooth gullets as done by Paul Sellers ().
BTW, all manner of graph paper is to be found on the internet in downloadable *.pdf format. I found graph paper in 4, 8, 10, 12, and 16 TPI. I am sure that more choices are available.
Here, the coarse tooth gullets have been formed with a file:
And finally, the teeth were formed and set to a 10 TPI crosscut pattern. I thought this might make a passable carcase saw.
I used a Veritas saw file guide for the first time in this project, but found the fleam protractor scale was off by about 5 degrees*. I contacted Veritas about it, but am still waiting to hear from them.
I also had trouble with the rake angles, and ended-up having to file the teeth five times until I got it right.
Has anyone else found this problem* with their Veritas saw filing guide?
Is it heretical to replace the saw plate?
Turns out I’ve got a steel backed one that looks pretty much identical. This was my great grandfathers. It’s in my user rack.
This is my rack. They all see a fair bit of use
