I use a Lenox tri master 3 tpi and it cost around £95
Crikey, that's a lot less than I am paying!! Can I ask how long/wide your Lenox blade is, and how much use it gets? Mine is 4170mm (13' 6") x 1 1/2" I have been paying over double that for mine :/ I guess I could go down to a 1" blade which would save a bit....
Looking at the Conway Saw website I see they are charging about £160 for my size for their own brand TCT blade at 1 1/4", which is less than I was charged for the Trimaster, but still well on the way to £200 once delivery and VAT is factored in....
Mine are in use every day, often on quite heavy stock (the bandsaw is basically what I rip everything on) and about every couple of months or so I tend to spend a few solid hours re-sawing for veneer, usually oak at about 10-12" thickness. The blades hold up well but I find that with the two I have I am having to send them to be sharpened about every 6 months (they are still OK for most things after that time, but they are starting to struggle with the thick re-sawing by then).
Then the trouble is that there is no one local to me who can sharpen them, as it's a bit specialised, so I have to pack them up and send them away, and then I am being charged a lot for the sharpening itself. Last time I was charged £50 plus VAT each. And I have had two blades break and lunch themselves inside the casing in the last year. A simple break would be OK as they are cheap to re-weld, but the way mine are breaking they can't be repaired, and that is the real killer. I de-tension them every night, and the breakages aren't that frequent, but if it means buying a new £200 blade every time it happens then I'm not sure the TCT route makes sense anymore — my calculations when I went this way were based on the assumption they could be re-welded several times during their lifetime.
So now there's always a bit of dread in the back of my mind now when I make a cut — is this cut going to cost me £200?! I can't work out why the blades have get so damaged when they break. I wonder if the heaviness of the Lenox bands are behind it.
