It was really hard (impossible for me, to be honest) to get the end-grain smooth. The fibres seem to lay down like a field of wheat. Even after I managed to sand it more-or-less ok, you should have seen the mess after I stained it! Every microscopic blemish, and every macroscopic one too, of which there were plenty...
Funnily enough, though, the sanding disc does a perfect job. But you can't finish a bowl on a sanding disc. Is there another technique I should know about? (Apart from sharpening the chisel every 10 seconds?)
Graham
Graham
