Dan689
I’ve recently restored a stanly No4 as per one of Paul Sellers videos. I’ve come to set the plane I’m only getting a shaving from the center of the cutting iron. Nothing on the left or right.
I’ve used my Veritas guide and the cutting iron is perfectly square with a 25 degree bevel to 1000 grit + stropped.
I’ve also flattened the sole and checked again and again..
It’s been suggested I tighten down the frog and chip breaker which I’ve tried but no change..
I can obviously wind out the cutting steel to get the sides to cut but then the center take a much heavier cut
Logically I want to say the iron is heavily rounded or the sole has a hollow but neither is the case..
Any help would be greatly appreciated
