I am restoring some old sash windows for a listed building and while I can find several cutters that produce a shape near the required, ( for example here: https://www.machinery4wood.co.uk/CM...-set-635-radius-x-12mm-cut-x-1-2-shank/P37457) they all seem to be rounder than I require. Its the rounded section of the ovolo that is giving me the issue, I need to be more elongated and almost an ellipse.
Its a very common profile on many old windows that I can find .... I realise that a spindle moulder is the answer , but I dont have one, and wanted if possible to try and make these myself. So was thinking I ask here and maybe some of you might have some suggestions where I could get the required cutter or if indeed one does exist?? Overall size is 35mm tall and 18mm wide
Obviously if no joy, I will have to approach someone who can make a cutter up to match and get them run off.....
Cheers, Mark
Cheers, Mark
