MARK.B.
I just watched those vids by P.Millard and now i find myself Wondering, Track Saw Hmmmmmm do I really need one, and the answer has to be no in truth i dont But i'm gonna get one anyway
Thanks. Good infoI would say that if you have a large CNC machine and it can cut sheet goods quickly then your answer is no. Likewise if you have a large workshop and a large industrial tablesaw then no. I looked into tracksaws and came to the conclusion that they are ideal for site work, small workshops without space for larger tablesaws and more importantly you work mostly in sheet goods, ply, weetabix and Mdf. I only have a small table saw and not much space, don't use a huge amount of sheet goods and when I do I just get them precut close to size and then finish on table saw. If I need to cut full sheets or ones too large for table saw I have a length of angle iron that I clamp down and just run my Bosch saw along it and that works great.
If you want to compare tracksaws then here is some info Track Saw
Ha no. My cnc is for my work but i was saying my only site work is renovating my house. Has a loft conversion so a few doors to cut down on angle so track would be good for thisY
You have a CNC machine for home renovation?
Its a 10x5 with 12x automatic tool changer. Here it is mid installationWhat sort of CNC machine? Never used CNC with wood but have for cutting sheet metal.
Well that hasn't helped meI just watched those vids by P.Millard and now i find myself Wondering, Track Saw Hmmmmmm do I really need one, and the answer has to be no in truth i dont But i'm gonna get one anyway
Thing is the full triton kit is only 30 more than saw itself and you get the track and 2 x clamps with itThis is why I didn't buy the Triton rails. The Evolution Rail Kit has 2 x 1.4m rails, so you use one for cross cutting full sheets and two for a full rip
Thanks. I will be making mft table tops on my cnc machine so not a problem really. CheersI'm a Tracksaw convert. I bought a Triton and an Evolution Tracksaw Rail Kit and it is working very well as a starter pack. The Triton works very well but check and adjust for square before using. The only downside I've found is the anti-kickback means you can't easily slide the saw back, so if you do an anti-splinter kerf cut followed by a full cut I need to lift the saw off the track and re-position (if anyone knows how to fix this I'd be grateful). The Evolution kit is good value but the rail doesn't stick to plywood very well so you do need the clamps that come with it and these are fiddly so I'm going to order quick lever clamps from Banggood this week. Be aware though, buying a tracksaw is the thin edge of a potentially expensive wedge as you get sucked into the world of MFT tables and associated accessories such as Benchdogs!
The only track rail that may be problematic is Makita as it has a unique anti-tip lip on the rail which is incompatible with non-Makita tracksaws. Watch Peter Millard's 10 Minute Workshop videos on YouTube, these are excellent as he shows you the differences and how to build home made jigs to avoid buying expensive Festool MFT ones.
I get that a lotWell that hasn't helped me
Thanks.Do you need a tracksaw? I guess the questions are:
For me the answer to all of the above is yes, so the cordless TS55 was ideal; and I've probably saved the cost of the saw over the years with the difference in cost of full 8x4' sheets from decent timber merchants (vs buying lots of 4x2' sheets from DIY stores).
- Do you have a small-to-medium sized tablesaw and find yourself manhandling sheets that are too large for your machine, and wishing you could cut them down a bit first?
- Would you like to be able to buy full 8x4' sheets from timber merchants (as the price per unit area is better) but don't have a large enough vehicle to carry them?
- Do you sometimes wish you could cut up a sheet outside rather than inside the workshop, in order to avoid creating lots of dust inside?
Sorry it was @Pallet Fancier my question.
