Lee Brubaker
A short while ago I posted a pic of a toy road grader with lugged "V" tread wheels followed in response to inquiries on how I made these wheels using a BS. Well.....last night I woke in the wee hours & was not able to get back to sleep so started to think about perhaps an easier way to make them. I have a radial arm saw and the first pic shows a wheel
pin mounted to a backer board which is clamped to the fence and aligned with the saw blade. The arm of the RAS is set 15 deg. to the right. The blade height is set to cut a 1/8" deep lug.
To cut the second wheel disc. the arm of the RAS is swung to the left 15 deg. The backer board reclamped aligning the disc to the blade. Both discs had the lugs plotted on them.
A 40 tooth finishing blade was mounted on the saw & the second pic shows the nice clean no chipping lugs.
This method is much faster than the case with the BS & no cleanup with a file is necessary.
Lee
[/img]
Lee
