cheers mike. I'm uk so metric
Thanks for this thread. Just fitted this kit to my 350 today to your measurements. Perfect job and works a treat. This is a great upgrade. Cheers.
Were you a bit apprehensive about making the first cut in the chassis?
Another option is to fit the Record Sabre guides to the earlier machines, been looking at this and I would initially only change the top guides. I think the Rikon machine is another clone based on Record or vica versa.
Cheers Mike
I have seen something similar that also reduces cutting height, why don't they design without the loss in cut!
Not proving easy to purchase this at the moment.The Rikon conversion resulted in a loss of about 10mm, so I can live with that. I am interested in your results if you decide to install the Sabre350 guides.
The Rikon upper guide replacement was fast...remove bolt, remove old guide, install new guide, install same bolt. The rest of the upgrade took time since I had to cut the blade guide and upper wheel housing. The Rikon doesn't have a safety switch in the upper wheel door, so the blade guide can be longer.
I would liked to of had a set of those on my saw but its not to he.Have a look at this thread: Axminster HBS350N / RECORD POWER BS350 Bandsaw Advice?
MikeeK,
excellent write up.....and photo's.....
just one small thing, in the future u would be better with a 3-4 mm hole drilled into the frame (or anything plate wise) at the internal corners....
then just cut to the holes...apart from a neater job it also stress relieves the cut corners, partiq on something with stress...
just sayin...
Dave,Well after reading up on that thread which covered the Axminster HBS350N blade guide set for upgrade on the BS350 I am all about ready to buy a set for my saw.
I have to just ask if I may. Mike K, are the sabre 350 guides the same as your Rikon guides with the exception to the extended front locking knobs for the side bearings on the top unit?
If there are close enough i might consider those as well.
Thanks you for your time everybody.
Dave
