Lons
Deema has given the technical padding to my suggestions Steve and it's reason I bought a Westfalia for my car including their specific wiring kit. I aslo used a local approved fitting company to supply and fit and they use the Westfalia coding instruments without which my car would have had major issues. The car has its' own trailer electronic stability function apart from the other wizardry.
Westfalia is the bar that Audi fit as standard but they quoted me almost £1100 rather than still substantial £750 I paid however, I have a twin axle trailer with a payload of 2 tonnes and just recently bought a large twin axle caravan with an MTPLM of 1800kg. Your 5 x 3 trailer won't be anywhere near that and won't exert the same sort of loading on your towbar.
If it's prone to rust, you can paint it as long as it's solid and I fitted Towsure bars myself to all 4 of my vans over the years without issues and they did a lot of towing.
The comments are correct about both notifying your car insurance company although mine, Aviva said they cover automatically and about insuring the trailer itself in case of theft or damage.
Also correct about grease on the towbar however I need to grease it for my trailer so the ball doesn't wear excessively and clean it for the caravan which has an Alko hitch.
Not quite correct when it comes to your driving licence. The changes only really affect those who passed their test after Dec 1996 but even then they are allowed to tow as long as the combined weight of vehicle and trailer are no more than 3500kg. It's a bit more complicated than that as further chages for tests from 2013 but all info is on the relevant gov websites.
Your Cee'd and little trailer will be way under that even though I'd guess you passed your test before 1997.
Bob
http://www.towsure.com/catalogsearch/re ... owbar+2014
Bob
