goodwinmagic501
Hello there, so before i get started i would like to explain why i am here. i recently wanted a new hobby and took a trip to turkey. here i bought a minature guitar and loved the idea of making one myself. so i did. however with no strings and it looks very rough. obviosly not knowing what tools, wood. paints or finishes i needed. i was still proud of the outcome.
basically what i am asking here is what type of wood should i be looking to use ?
I use a hand rotary tool kit with most drill bits and extensions (however i do not know what the bits are called or the uses. i generally use it for sanding, cutting and shaping my different sizes.
i have just started a new piece that is a little bit different that i like to call a 'jigsaw guitar' all the pieces are interlocking, so the guitar is not a whole piece but a bunch of seperate interlocking parts.
i used balsa wood. which you probably know is SUPER soft (i can push my finger nail in it and it leaves a dent. it think for my next guitar i should use a slightly harder wood? bass?
however like i say i am a complete novice.
also i don't know how to make the smooth edges, as when i try and sand the wood down or smooth it. it goes fury?. again i think this is because of the type of wood i am using?
i now would like to make a more 'traditional' minature guitar and was wondering if you guys could help me out with the above problems. also how to paint the wood to get a nice glossy finish?
PLEASE treat my like you would a complete novice who has never seena piece of wood before. let alone tried to carve one.
thanks in advance
Aaron
thanks in advance
Aaron
