devonwoody
Am I correct in thinking that to use this sharpening system, mass sharpening is not the way to go.
If you want to use the 220 grit, I would want to grind all my tools first at this grade and then change to the 1000 grit, but this means you have taken the blade out each time to start the next one and then you would not exactly match the original grind when putting the blades back in for second grind.
In the old days I watched my grandad hone is cutthroat razor on a leather strop which I think he impregnated with chalk or talcum power, anyone use something like this on their honing wheel?
