engineer one":1mixphv6 said:then it is often better to use a combination square, which gives you the chance to draw 45degree lines too.
woodbloke":3tg387r6 said:I always worry a bit that when I use an aluminium square with a very sharp knife I'm going to shave a little bit of the side of it, probably never happen.
engineer one":1ljhtn4g said:which is not too bad.
I also have a decent enough R&C combo square but I only use it for a bit of 'rough' work, eg if I want to put a pencil line across a board for cross cutting to size then this sort of square is very handy. For accurate work tho' it stays on the 'Tool Wall' and something else is used instead :wink: - RobPaul Chapman":sio14prg said:engineer one":sio14prg said:which is not too bad.
Well it is, actually - it's either accurate or it's not :wink: It's all about compound errors. A little bit out might seem OK but those little bits add up. When you come to put several pieces together, and they are all a little bit out, you find that the whole job is p****d. And with combination squares, if you want to use the outside edges, you have to have the blade fully extended, which is when its accuracy is at its worst.
If you are happy with the accuracy of yours, Paul, that's fine but I certainly no longer use mine to check squareness - but they are very handy for depth measurements; checking distances, say, from the router base plate to the edge of the cutter; making parallel pencil lines along boards, etc.
Cheers :wink:
Paul
Mike.C":oh6lb5ul said:The thing I like about the Incra is they guarantee that it is square when you receive it, and it will stay that way even if you drop it.
Mike
