ok, just checked a couple of things.
i actually have 3 combination squares too. a short one taiwanese/general make, which i use for checking on my tormek in sharpening. only 3inches long,it has very small error possibilities.
i also have two longer 12inch ones(boasting i know
one is a cheap and cheerful ally one. checking that i have found it is about 0.5mm out over 10 inches, which is not too bad.
i have also checked the axminster one i had bought some time ago.
that is i would say pretty spot on. interestingly of course, if you try to get the whole length of the ruler in use, you build up the inaccuracy since it has to be lined up with the ruler along the whole of the slot. so in fact you only get about 10 inches of useable ruler.
actually, i rarely use my combination for checking square, but i do use it as a marking gauge, much more accurate than a tape. and unless you make your own "proper gauge" rarely do they come in sizes of more than about 6 inches. so the combination square is a quick and dirty way of marking out, and with the square part, you can run along a board and get a pretty accurate line.
another useful tool is also a veritas one, which is an attachment that screws on to a steel ruler of standard 25mm width, so far i have found it too to be pretty accurate and square. the also do an adaptor which screws on to a rafter square which allows you to rest the edge of the square against a board edge.
you could also buy one of the plaster board 1200 squares, i am amazed how accurate they are and stay. 8)
finally you need both a 3,4,5 square and a set of pinch rods to ensure that things are square. and you can make the 3,4,5 out of a piece of mdf or ply, whilst the pinch rods are also easily made at home from strips of 3/4 wide by 1/2inch thick hard wood clamped in the middle, and extendible.
paul :wink:
