Found a screwdriver nearly 33 inches long. I can't imagine any need for that length, except to reach some deep inaccessible places. Still I suppose it's always good to have a big'un, as the Actress said to the Bishop.
Watch out you will upset the wokies, innuendo's, thinking that gender is real and religion all in one line!Still I suppose it's always good to have a big'un, as the Actress said to the Bishop.
I thought innuendo was an Italian suppository!Watch out you will upset the wokies, innuendo's, thinking that gender is real and religon all in one line!
I'm probably wrong but doesn't a longer driver give more turning force? I've always found it easier to undo a screw with a long screwdriver over a short stubby one.
You could be losing torque due to torsion in the longer length, it is this which gives you that feeling but a larger diameter handle would allow you to apply more torque easier.Yeah, me too. I have no maths, etc, to prove it, but I too always had the "feeling" (sorry!) the longer the screwdriver the more torque I'm applying
The torque at the screwdriver tip must be the same as at the handle - unless the handle turns independently.You could be losing torque due to torsion in the longer length, it is this which gives you that feeling but a larger diameter handle would allow you to apply more torque easier.
Or the screwdriver shaft is winding up like a rubber band, which is highly unlikely.
Absolutely right. But the torque at the driven end of the shaft (the screwdriver handle) and that at the driving end (screwdriver tip) will be the same.Actually, not so unlikely as you may assume. For example, in turbo prop aero engines (i.e. a gas turbine driving a propeller via a gearbox) measuring torque is an essential in flight parameter, and in most of these engines, torque is measured by looking at the amount of twist on the drive shaft as power is applied (or reduced) by the turbine. Looking at those shafts, it's almost inconceivable that such a shaft could twist (even just a tiny bit of course). But they do.
So I'm not surprised that if a screwdriver blade is correctly engaged in the screw head, and if the handle can be gripped well, it actually IS possible that the screwdriver shaft does indeed twist a tiny little bit - of course not the rubber band that Adam suggests, but yup, a tiny tiny bit.
The above IS my serious "guesstimate" BTW.
The extra force you are able to apply is becuse you have got your hand and arm tighter into your torso and body mass instead of having arm more extended.
