Pete Maddex":2ed31jua said:Hi,
I think the answer is right in front of us, how many problems has this forun solved? and how much advice been given.
Pete Maddex":1g53fpcc said:Hi,
FrCollins":14absze1 said:Two successful woodworkers; one is highly skilled at using hand tools with little knowledge of power tools, the second is highly skilled in using power tools and has little knowledge of hand tools....
I started in this game of butchering timber as an Antique furniture restorer, and by that I was using 90% hand tools in my work.I see myself as a contemporary cabinet maker, so I have no shame in embracing modern construction techniques and tools along with the more traditional, and neither should hobbyists. After all, all time is precious whether it's in a professional capacity of otherwise.
I agree - although it's not just this forum or even just those currently in existence, if we're talking the whole decade.Pete Maddex":203dhz9r said:I think the answer is right in front of us, how many problems has this forum solved? and how much advice been given.
Ross K":3czjdvtq said:I have no shame in embracing modern construction techniques and tools along with the more traditional, and neither should hobbyists.
yetloh":65jo6qwb said:Absolutely. Chippendale would certainly have used a Domino if it had been available, not to mention MDF.
Jim
Mike Garnham":19uss5le said:However, I cannot for a minute think of any piece of Chippendale furniture that would have had a place for MDF! This was high-end stuff, sold to the great country estates, London businesses and Royalty. I'll bet the designer-makers and manufacturers working in these markets today don't use MDF on similar pieces, so I think it is stretching credulity to suggest that Thomas C would have used it.
Mike
Mike Garnham":39u39zdp said:I'll bet the designer-makers and manufacturers working in these markets today don't use MDF on similar pieces, so I think it is stretching credulity to suggest that Thomas C would have used it.
Mike
wizer":2u3gn5jy said:What about Dado heads?
**Runs away ducking**
:lol:
yetloh":2pica0fv said:I hate MDF too but that is not the point. Sheraton or any other top maker of whatever age would always want to use the best material for the job. In this respect there is in my opinion a better argument for MDF than for the Domino jointer. I say this on the basis that, in tests, a traditional tenon has proved stronger than a Domino although the difference will in most applications be immaterial. However, I do not believe there is a better substrate for veneering than MDF. The alternative is ply but ply will sometimes twist which MDF will not. Yes, it must be solid lipped (but so must ply) but it will then be the closest thing possible to a completely stable panel which is what is required in fine furniture. If the Edward Barnsley workshop (and numerous others) thinks it is the most appropriate material for the job then that is good enough for me.
Jim
Mike Garnham":1hx5c07i said:entrenched views
