carlb40
Sooo onto today. I have started on what will be the front panel of the box. First up was the ply panel, which was actually prepped last week. I taped the veneer into place to form a hinge. Flip it up, apply glue, pop down. Done
While getting ready though, i removed it, put some selotape along the length where there is no veneer - so the glue doesn't stick to it. Then taped the veneer back into place.
As some might notice the veneer looks a bit short. That's because it is :lol: That is the bottom and i will probably add a piece in later. It won't be seen as the skirt will cover it.
Next up was cutting the inner veneer to size.
Then i noticed a small split, it must have happened after i cut it. So some first aid was applied
Then began the setting up process. First up some packers - trespa in this case.
Then the bottom cauls
Then 2 - 18mm mdf platens - yes i cut them up this time, along with the grease proof paper.
And as you can see clamps/ roller at the ready. Plus bigger clamps just out of shot.
Glue was weighed and mixed and rollered onto the ply. Then veneer added and rolled. More grease proof paper on top, then 2 mdf sheets, cauls and clamp time.
Aaaaaand relax and breathe
But wait, what's happened there? After looking and carefully checking to make sure there is even glue squeeze out. One end of the veneer is over hanging the ply by about 5mm :shock: It is sized about 1.5mm extra all around.
Ahhhhhhhhhhhhhhhh the veneer has slid during the clamp up. :twisted: Quickly undo clamps, remove mdf etc. Then carefully slide veneer into place again. Not easy as the glue has a good grip on it. Sorted, put everything back.
Start to clamp up again and it moves yet again. Move veneer again, this time i taped it to the bottom mdf. Put it all back and start to clamp up again, and the veneer is sliding again. :twisted: So off it all comes. New grease proof as the glue is everywhere. This time i used selotape and taped the top piece around and under the bottom.
So put everything back again, clamp up. This time veneer stays put. Ha that will teach it, no one messes with me and gets away with it. :mrgreen:
So there it will stay, in clamps till tomorrow morning. I just hope the veneer sticks. :-k
