graduate_owner
My Denford Viceroy takes the same tool post as my graduate, 1" diameter. According to lathes.co.uk, the original rests were 6 and 12 inches long.
K
K
I thought it might be worthwhile to compile a list of post dimensions and any other useful information for use when hunting spares, different sizes or improvements.
Axminster AT1416VS takes a 1" stem (25.4 mm)
Axminster AT1628VS takes a 1" (25.4mm) stem 4.75" long (min)
Axminster AH-1218 and AH-1218 VS takes 16mm stem (according to manual).
Axminster AWSL takes 16mm stem ATM.
Axminster AWVSL 900 and AWVSL1000 takes 25mm stem ATM.
Axminster KWL (and probably other badged 37" single round bar Taiwanese lathes) 7/8" stem 2" long.
Axminster trade series precision Pro Lathe Takes 12.5mm stem ATM.
Axminster 1216VS 1" 4.75" long.
Axminster AWVSL Mini 5/8" stem
Ax AT 2030vs 30mm
Charnwood 870 25mm
Charnwood 813 25mm
Dominion 1 1/4" stem
Draper WTL 12 22mm stem 52mm long
Hegner 20mm
Jet 3520B takes 1" stem 6" long
Jet 1014 takes 5/8" 4" long
Jet 1642 takes 1" 6" long
Jet VS1221 5/8" stem
Killinger KM1450 SE (and possibly all Killingers) 30mm post
Myford Maestro 1" stem 3" - 4" long.
Myford ML8 3/4" stem
Nova DVRxp and 1624 - 44 1" stem. 8" long for the DVR, the Galaxi and the old 16 - 2448, and 5" long for the Comet.
Poolewood 28 - 40. 30mm diameter, 90mm - 95mm long - a bit longer wouldn't hurt. Shorter would handy as well - sometimes when working on very small stuff the rest has to be set too high in order to clear the bed bars.
Poolewood 1500 30mm post
Poolewood DVSL 25mm
Poolewood Euro 3000 30mm stem
Record CL (old) 3/4" stem
Record CL (new) 1" stem
Record DM 305 3/4" stem
Record DML 320 1" stem
Record DML 24X is 3/4" or 19mm
Record Power DML 36 SH MK2 Two rests.
W 9 3/4" D 3/4" L 1 3/4"
W 9 1/2" D 3/4" L 1 3/8"
Record DML 305 3/4 in stem (as above)
50 mm stem length to shoulder, (60 mm would still clear the bed in lowest position)
70 mm from shoulder to working edge of the rest (on the standard 200 long rest as supplied) making total height 120 mm.
Record Power Coronet Envoy (and so also Regent ?) takes a 1’’ stem.
Record Herald 1" dia, 4 1/2" stem.
Sorby 25mm posts - M12 x 1.25 thread.
Titan 400 40mm stem 125mm long
Titan 315G 40mm stem
Titan 315 40mm stem
Twister FU 180 banjo is 1" stem 3 3/4" deep.
Union Graduate 1" post 2" long
VB 40mm stem
Vicmarc 150 1" stem
Vicmarc 175, 200, 240 & 300 30mm stem
Wadkin BZL 1" stem
Wadkin RT and RS 1 1/8" stem 1 7/8th long for 6", 3 3/4" for RS 8" and 5 1/2" for RS 10"
Wivamac DB1000 - 1" inch stem
Woodfast C1000X 1" stem
Just for the sake of completeness, my Tyme Cub toolpost dimension is 16mm. Bought secondhand Coronet Minor toolrest which is 5/8” and had to drill out to 26mm. Works a treat now.Tyme Cub 5/8" post and about 2.5" from bottom to tool rest bar
Sorry - meant 16mm not 26mm in final comment.Just for the sake of completeness, my Tyme Cub toolpost dimension is 16mm. Bought secondhand Coronet Minor toolrest which is 5/8” and had to drill out to 26mm. Works a treat now.
