As I posted a while ago, my tools suffered some severe exposure to the elements due to shed failure... Largely, wire wool, elbow grease and a quick sharpen were sufficient to sort them out, however one or two ended up badly pitted behind the cutting edge necessitating rather more material removal.
I ground two of them today, starting with a belt linisher which didn't work nearly as well as I'd expected, and then with a more conventional pedestal grinder, I achieved decent results in the end but can't escape feeling that I was missing something... The finishing machine had no work-rest which was unhelpful, but the multiple rounded facets it generated could only be down to an inappropriate machine, or poor technique.
The grinder was rather slower, due to more rapid workpiece heating (conveniently, it has a small tub for coolant which fits into the pedestal), but generated a single 20° bevel* quite easily, with a minor touch-up on the edge of the wheel taking any hollow out.
How would I be best approaching Grinding tools, other than slowly, with frequent cooling? My approach so far has been to set the workrest to 90°, square the edge up, and take it back past the worst of the pitting, (2-3mm), then turn off, set the work-rest to the desired angle and slowly work back towards that edge until I can't see any light reflected off it, then lightly dress against the side of the wheel, and sharpen on a stone as normal.
* I know that 25° & 30° are "normal" but for working with softwood, especially whitewood I favour a more acute angle, even if the edge is more fragile.
