Choosing a Bench Grinder
I bought an 8" slow grinder from Hope Wood turning recently. Chose the option with a 240 grit CBN wheel. I'm very pleased with it so far, and excellent service from Hope.
You will be VERY vulnerable to burning steel on a high speed bench grinder with a 240 grit CBN wheel. I use80- and 180 grit on a half-speed machine. I can do most all with 180 grit. For a full speed machine, 80 grit would be better.
Regards from Perth
Derek
Yes. That's why I took the time to find a slow grinder that is particularly suited to this role. I have had no problem with burning the steel.
I'd opt for a variable speed grinder....which typically runs 1750 to 3450 RPM
Callme nuts, but I use several different deburring wheels, some of whom will tell me they don't like 3450 rpm,
And I know it's not common in the woodworking fiarena, but I also use loretone expandable rubber wheels from the lapidary side of things, and they DEFINITELY do not ike 3550 (the belts simply explode!
