Too early for Xmas scrolling?
Claymore":2ymespj8 said:
...Ruth asked where are the stained glass windows? 9-)
The pikeys had them away while they were nicking the lead off the roof.
Homerjh":1bk889qj said:
nah, made a start on some festive tealights....
I like these, what type of wood is it if you don't mind me asking? I was going to try and make some out of old oak barrel staves that are no good for anything else, not sure if inch thick oak is the ideal wood though.
beganasatree":3et3s60o said:
Do you use the complete string for each house or can you shorten them?
I only have one string and I'm swapping it between houses for the photos.
I presume the LED's are wired in parallel ( I think the voltage drop across each LED would be unworkable for series-wired LED's). So I can see no reason why you couldn't shorten them providing you insulated the wire ends after cutting.
We had a good discussion about lighting a while ago, but to save you having to find the thread, here are some links.
As an update to the using the 5m strip of LEDs. As I say, they can be cut into multiples of 3 (ie 3, 6, 9 etc) and you'll need to wire up the individual strips to a mains transformer plug. You could cut some wire and solder them onto the LED contacts but I came across these brilliant solderless snap connectors.
http://www.banggood.com/Solderless-Fema ... ds=myorder
These 240v/12v transformer plugs will attach to the solderless connectors or the small press fit wired connectors (shown in the link below). There are lots of pictures here so you should be able to see how it all fits together.
http://www.ebay.co.uk/itm/291085358157? ... EBIDX%3AIT
Barry
I have been 'instructed' that I should use mains-powered lights rather than the 4.5v battery pack ones. those links will be invaluable, cheers.
Barry,
those links will be dead handy and they are really well priced.
I'll add them to my wish/watch/favourites.
Phill
You're extremely welcome. There appears to be several people selling this type of stuff but at least we know what the bits are called and how it all fits together.
Barry
Hi Naz,
I was going to make one of your pallet wood houses with the lights inside.I have bought the lights and have the wood but now I am not so sure ,after a visit to ALDI and was confronted by dozens and dozens of boxes of the same houses priced at £9.99.There goes my idea of something different for the next Christmas fair.THERE IS SOME DIFFERENCES BETWEEN YOURS AND THEIRS.
Peter.
I have the monopoly around here too, our nearest Aldi is 45 miles away. :-D
