Thanks Paul and Mark..... I'm glad you like the links.
Jesse, I did this on the weekend. Took some photos as I went. I was thinking they're a nice alternative to cutting your regular T&G joints. Its a spline joint. Saves on having to prepare that matching cutter to cut the tongue.
http://i33.photobucket.com/albums/d74/apricotripper/1g.jpg
http://i33.photobucket.com/albums/d74/apricotripper/2g.jpg
Its going to be a top for a metal drafting table I found and have cleaned up. Its just regular pine that used to be old bed slats. Bit of a scavanger I am. The splines is just hardwood ripped out of an old fence post I found on the table saw
. I'm trying to be clever by having contrasting colours uno. :lol:
I did these with a record 44, but I don't see any reason why you can't do them with your Sargent, once you get it all tuned up.
All you need do, is setup a plough blade, everything parallel and that blade sharp of course, and keep that fence referencing the same side of the table top for each board. uno, to ensure accuracy. And groove every board both sides.
Plough plane cuts along an edge are very stable and quick, and shouldn't take long. The goal is to, have all the boards grooved to depth before that blade bluntens. At the very least ensure the grooves for any particular joint is complete before removing that blade, cause removing the blade risks inaccuracys that occur when resetting it...ie. it can be fiddly trying to get a blade sitting exactly as it was before.......if you know what I mean (? I'm not sure if I was clear enough) ....
You probably know already, but try and get the very ends of the joint tight, so it looks neat and gapless. Actually its probably a good idea to have the splines a little loose between the ends so they bind up well when you add glue etc.....as long as the ends look tight.
Anyway, there you go.....an alternative
[/url]
