Toilet issue's.. it had to be asked......
stevebuk
23 Jan 2007
Nottinghamshire
ok then, so you are in the middle of turning and suddenly you realise all the coffee you just had now needs to be emptied, as i do not have a smock at the moment and my toilet is inside the house and SWMBO dont want shavings shrewn across the floor, so before i can relieve myself i have to hoover myself down, which in turn can take 5 precious painful minutes.
So what do you do instead of dropping shavings everywhere??
I have an outside loo,next to the workshop.
Otherwise,I just walk shavings into the house,and vacuum them up later... :oops:
Andrew
Steve
Get laminate flooring then it just sweeps off :lol: :lol:
Or a long hose pipe :lol: :lol:
Malcolm
:lol: :lol: I'm treating this tongue in cheek Steve, but if you are serious you can pick up second hand Porta Potti's for £10. Pity you where not a bit closer I've got a old one in the shed we used when tenting years ago.
Or as I do at my allotment, pee on the compost heap, or if the ladies are down pee in a plastic jug in the shed, then dispose of it.
Or as has been suggested, stand up for yourself man! What are you, a man or mouse? After all what's a few shavings between friends.
Mind you I've sorted 'er indoors out about wood chips, I do my turn at house work. :oops: :oops:
George, been married for 30 odd years you don't have to tell me. I can do anything I want, as long as 'er indoors lets me. :oops: :oops: :roll:
I have brush next to the door....have got shavings on carpet..
Down to me to clean up..as long as I do no complaints..YET :lol:
Suppose as long as I do not get any in the bed shes happy :wink:
ahh see the 'smock' that I use is made from that waterproof material and the chips just fall off. So a quick dusting and I can get away with walking through the house.
Tho the missus does keep saying that if I got rid of the workshop we could have a down stairs loo.... :roll: :( :cry:
I always find that most of the chippings come off my shoes/trainers.So i just slip them off before trapesing through :shock:
But it only takes five minutes to run the vac over :D
Well, I do wear a smock and that helps. so does an air compressor which gets most of the chips off my beard, hat, arms, and other places. I wear slip on shoes, and will take a broom to my socks. I have thought about one of the painters Tyvek suits/overalls (don't know if you have that over there, but a light weight (Dupont) material used for wrapping houses to keep out moisture but breathable) which will shed almost anything, but I am one of those 'hot' people... 'Are you crazy, wearing shorts in this weather?' Shavings happen. Not so crazy that I would try turning in the buff, no matter what the weather was like, but then with my pelt, it would still attract a lot of chips. You wouldn't really want to see that.
robo hippy
