dunbarhamlin
New fret slotting saw then?
ivan":2688e9jd said:Most helpful advice I ever found was in an early FW mag. Make a handle for the point (far end) of the file, and do it thus:
Cut yourself a matchbox sized slip of wood, but a bit thinner. Drill a hole in the middle of the striking surface (if it was a matchbox) small enough to hold the point of the file firmly. Cut through the block making sure you clip off 20% of the hole, at an angle (more later) Glue block back together; X section of hole now looks something like this C/ . When you push in the file, one flat of the file is aligned by the flat side of the hole. Arrange to cut the block at the correct angle so that when block is held horizontally, file cuts tooth at correct angle.
Agree. I have more than a couple of DT saws and so should really do the same. I'm using a resharpened LMI at the mo, but when Master Wenzloff eventually reaches somewhere near the bottom of his custom orders pile, there'll be something rather nicer.MIGNAL":1fsmh1i3 said:Quite a fancy saw for cutting a few slots in a fretboard but I haven't be overly impressed with some of the commercial offerings.
