Fromey
After hand dimensioning some cherry, I proceeded to mark out a mortice to cut. I decided not to use the drilling then chiselling approach, but to chisel it all out manually (practice and masochism). I made good progress and as I approached the other side, I put the wood onto a piece of scrap to prevent going through to my benchtop. Hmmm, stupid! #-o As I chiselled through to the other side, I heard and ominous "crack!" and sure enough, the other side of the cherry had cracked out. Perhaps the wood had risen slightly from the waste wood underneath and allowed this to happen. Or perhaps I'm just a dim-wit ](*,)
Ehhe,ahem
So, I sat down with the Internet and a few woodworking books, and to my surprise, I can find no guidance on how to correctly go about cutting a through mortice. Possibly because it's so obvious it doesn't bear communicating, or maybe everyone in their right mind would drill out most of the waste first, but all instructions I can find make no mention of precautions, etc.
Am I correct in guessing that the best way is to mark out the mortice on BOTH sides of the wood and then chisel from BOTH sides, meeting somewhere in the middle? Or is there some other Old Master trick (like just get on and drill it)?
Thanks in advance.
Ehhe,ahem
Thanks in advance.
