Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
Sorry - late to this:
The 13A plug+socket is the worst possible design for it's job - awkward, bulky and expensive to make, and p**spoor at actually mking a connection. Steve Maskery's right - the metal blades don't work at all well. They were introduced post war as it was thought that the ring circuits they enabled would save scarce copper over the earlier fused-spur systems. They probably did, but in terms of a low resistance, reliable connection, the old 15A round-pin ones are far better (as long as they're not Indian!).
Anyway, there are several reasons why stuff gets hot:
Firstly there's the poor connection between plug+socket, as Steve said. You can help this by either replacing the socket altogether, or carefully dismantling it , cleaning and re-bending the two brassed grips for each pin (yup - take the power off first!!!).
The other one is inside the plug itself. Run the kettle to boil a full load of water. Whip the plug out and feel which pin is hot. If it's the live pin, chances are it's either the fuse in the plug itself, or the contacts for the fuse making a bad connection. This is VERY common, especially with powerful kettles (3kW) and fan heaters (also usually 3kW). The obvious thing is to clean the fuseholder and fuse ends, and make sure the fuse is gripped well.
It may also help to change the fuse, even if that's still working. At 3kW power they do get quite hot, and the filament gets 'tired' like a light bulb filament does. A new one will have a lower resistance.
It's probably too late to be helpful but might yet be useful to someone.
E.
E.
