John Hall
Stick with Loctite…no pun intended..
do not use silicon'loads but will be subject to vibration. I can use nyloc nuts in most places but not all.
When I used to fix car engines back in the 70's, it was copa-slip for threads you wanted to undo, red (or green?) Hermatite for stuff you wanted to stay put. It doesn't exist any more, my initial thought is a smear of clear silicone sealant on the thread but any other suggestions welcome. The objective is to prevent any looseness and noise.
Thanks all.
As usual lots of good information and diversions which add value. Gasket reference sparked memories. I never had a gasket-free Ford sump but I did once buy some 'instant gasket' to fix a distorted thermostat housing on my Hillman Hunter. Worked, outlived the car if I recall correctly. Piston ring broke at 167,000 miles and not worth the rebuild 'cos all the other bits had done 167k miles as well. A flatmate I shared with in the 70s had an Anglia 100E, side valve engine, which was 'chuffing' round the cylinder head so he coated the gasket both sides with araldite, torqued it down and sold the car. Not sure I would have done that (ethically) but often the car tax was worth more than the car back then and you could get almost anything from local scrapyards.
Loctite it will be. Probably blue 242, hoping never to dismantle but using heat to release the red sort might be impractical.
I will be using shakeproof washers of many kinds wherever I can so this is belt and braces. My son is an orchestral percussionist and has a huge range of instruments, but we plan to restore an old orchestral bass drum and an unusal floating head snare drum. In both cases there are fittings bolted though the shell, and if you get any loosness of any kind it sounds like a swarm of angry bees. If you do get a noise its often a real pig to identify where its coming from and a lengthy job to get to it. The snare has occupied much frustrating time already so full stripdown and rebuild is the only answer.
and about the car tax being worth more than the car
