ByronBlack":3amgjrye said:I've got to a stage where I need to thickness a piece of wood that is too wide for my 6" planer/jointer. It's about 13" wide.
I need to take around 5mm of and a leave a surface that is flat enough to receive a 5mm maple veneer.
Now, do I go the power-planer route? or should I use a hand-plane? I like the idea of using a hand-plane, but not sure how difficult it will be to get a flat surface good enough for the veneer compared to a finished surface from a power-planer. If I do use a hand plane, is a scrub-plane a good idea of a Jack plane?
Or are there other alternatives? I read a short article on another forum of someone making a jig for use with a router? I have a router so quite like the idea of not having to buy another tool.
Advice, as always, greatly appreciated.
ByronBlack":vr3dkd88 said:Jason - I did think about the issue of the bolt heads, and I will be making the clamps a bit thinner so that the bolts are quite a bit lower, good point about the double-sided tape, i'll have to experiement with that.
Magnate do a planer cutter for the router , you can get them thro Woodworkers workshop .co.uk , i have one myself .ByronBlack":pn8fru88 said:I do have a router (not sure what a 'tailed' router is though). I have a Ryboi 1/5:
Where would I get a flat ended cutter, most of my cutters are either flush-trim, straight cutting or of the decorative variaty. I do like this idea though, i've seen it a couple of times, and i'm loath to by any more power-tools and would prefer to do it myself.
If you can point me in the right direction for the cutter, I think i'll do it this way.
