corian is 800mm x 60mm x 12mmFecn":yso52mon said:I believe the magic number for bending corian is around 140C-160C... If you get too much over 180C, the corian can start to blister. If your corian is 60mm thick, I reckon you'd need a good couple of hours at that temperature to allow the heat to work it's way to the middle.
I expect you'd get it hot enough with airguns and a box, but you'll have a hard time maintaining the right temperature. An oven may be a better bet.
3 mtr suggests a worktop?adidat":r7o8v2k6 said:Do you think a college would have a facility to heat up 3m of corian?
