CHJ
Paul, more pictures of how I keep my green wood until I can get round to using it.
Paul Johnston":1kelus1q said:Which is the best and easiest way to split them.I do have a chainsaw![]()
Paul Johnston":1kelus1q said:Is it worth keeping the offcuts as in the second picture where the branch is breaking off.
Paul Johnston":1kelus1q said:Any idea what the wood is.I thought it might be Ash :!:
Paul.J.
PowerTool":1ba367km said:You've had some very nice pieces of holly - were they just air-dried,or have you treated them to some meths or water to speed the process up ?
I find that holly cuts and finishes very nicely,just awkward to dry.
Andrew
Paul.J":2y2aw4il said:...snip...
Did the knots cause any problems.
What finish did you apply.How long did it take.
Paul.J":3nf37o5a said:What sort of moisture levels are you looking at for turning,as all the timber is kept outside,left for a priod of time to dry-turned and then brought into a drier enviroment.
So far the few pieces i have turned have all had some movement on them since bringing them into the house.
I had to balance it fairly well by removing surplus protrusions with a power plane, the smaller motor on the perform does not have a surplus of torque (it's a cheap condenser run as opposed to condenser start motor) turning was slow so as not to stall it. Not a bad thing as newbie though.Paul.J":3nf37o5a said:How did the Perform,perform with a big heavy lump of wood like the one in your photo :?:
Paul.J.
