Hi,
I've got a few outdoor projects I would like to build, the most pressing of which is some field-style gates. I have enough wood work experience to be able to do this, but probably not enough to get it right I'll be content if I have to re-make this in a few years as long as I learn something in doing it.
That said, the biggest stumbling block I've hit so far is what material to use. Do I go for pressure treated softwood, because it's forgiving of mistakes (financially) and likely to survive outdoor well? Does glued joinery work in pressure treated wood? I'm planning to use field gate hinges, so I'm assuming that securing timber that is a good fit for the width of the hinge is important. What happens if the dimensions are not quite right - presumably thicknessing etc is a bad idea due to the impact on the tools, plus removing the outer layers of wood that carry the treatment seems dumb.
Secondly, I'm concerned about my ability (as a DIY punter) to get hold of sufficiently straight boards for the longest of the 3 gates I'd like to build (3.5-4m, depending on the exact position the post turns out to be, allowances for hinges etc). I'm assuming commercial outfits can afford to buy a truckload and cherry pick the best specimens for their longest gates. Any thoughts on this? How much excess should I allow for having to trim when speccing my raw material, please?
Very dumb questions, I know. Any tips/tricks/major pitfalls to be aware of gratefully received..
Many thanks.
Many thanks.
