Derek Cohen (Perth Oz)
Hi Derek - have you found them favorable to use? I guess that's not much of a question to ask, they are a function of their fit, as you've said - if everything is locked down tight and they are set up properly with the iron matching the sole, life is good.
Hi David
As you know, the thing about used and old woodies is that wood moves, and nothing is the same as when a plane was new. Especially with moulding planes, the iron must fit the bed.
My set needed a fair amount of work to dial them in. Although the irons had plenty of meat in them, there was not much clearance behind the wedge. The wedges needed to be adjusted a little (by planing them down - which retains their shape and fit, but reduces their depth), and then the blades needed to be reground and sharpened. Once done, they worked well.
I also have a full set of beading planes that, despite having been little used, still needed to be tuned up to fit the sole.
I think that the only time one will obtain a moulding plane that works out of the box is when it is brand new - the only one like that I have had is a mini panel raising plane from Philly. Ironically, much of the pieces I have build in recent years have had curved edges, and I have resorted to scraping a bead (just ordered the new LV beader).
Regads from Edinburgh
Derek
