Tenon Jig for table saw
RinkyDinky
1 Nov 2006
Beautiful Shropshire
I want to buy a tenon jig for my table saw and have seen that Rutlands ( :shock: ) have the Dakota one for about £90.
Anyone know of any alternatives or has anyone used the Dakota one and can recommend it?
I want one that is precisely adjustable if possible.
Thanks for the replies .... :D
I made one to slide along my rip fence. Since the rip fence is micro-adjustable, so is the tenoning jig.
Its very easy to make. I think someone else had the same idea and posted it on this forum. Do a search for 'tenoning jig'.
Thanks for the positive recommendation Mike, i will probably get one if you say it's worthwhile, as i have quite a few tenons to cut and would rather work on my forthcoming project than make one at present. Time dictates in this instance!
Kind regards
Ben
i have a dakota jig and it needed a little shimming with paper mainly to put the face in line with the slot and also square with the table. the bar also needed punching to swell it a little. after that it was spot on and quick.
johnnyb,
I have a dakota jig and it needed a little shimming with paper mainly to put the face in line with the slot and also square with the table. the bar also needed punching to swell it a little. after that it was spot on and quick.
No problem at all with mine.
Mike
The woodcraft has adjustment grub screws to take up any slack if required.
Alan
