Taper Some Grooves Into Oak Board For Belfast Sink Drainer??
scouse12345
6 Nov 2009
Merseyside
Evning all,
Anyone know how i can taper some grooves into oak board i'm turning into a belfast sink drainer..??
All suggestions welcome..
Ta..
scouse
You need to construct a sled that the router is fixed to that slides on some tapered runners fixed to the worktop. A drawing would make it clearer, but hopefully the words may give you the inspiration...
Ed
trend make a jig for that exact job, dont know how much they want for it tho, considering you'll probably only want to use it once. could always sell it after youve finished i suppose.
This is my general arrangement for similar-ish jobs:
The plywood has screwheads underneath to limit extreme movement. In this case I was planing so no stops, but I clamp a stop on the ply "bridge" for a single groove. Candle wax rubbed on the rail tops make it go smoooothly. The Dexion is clamped to the bench at each end with packing underneath to get a slope as required. For working directly on a surface like a worktop you may need to use thinner "rails" depending on the maximum plunge depth of your router.
Good luck
Boz
When I left school I worked for a while in the stores at our local Council depot. I often watched the joiner there grooving draining boards for Council houses. He did them in 10 minutes - maximum, just using a wooden moulding plane. No jigs, no guides - just freehand and perfect every time.
Richard
