MikeG.":25fzze6u said:A couple of things. Firstly, 450 deep (minus the depth of the back panel, presumably), isn't deep enough for a coat hanger with shirts or jackets etc. I make wardrobes 700 deep (650 min.). Secondly, I'd be making the sides out of a paneled construction, rather than solid boards. Just make sure you have a cross-member to suit shelves and hanging rails etc.SMALMALEKI":25fzze6u said:......I don’t have a plan but what I have drafted is just short of 200 cm tall and 45 cm deep. Has three main compartment of 58 cm. ........
Hi Mike
Thank you for your advice. The reason I went 450 was because of the room this is going to put in. 700 mm could possibly be slightly too big for the room. To make room for hangers I was planing to get the rail front to back rather than side to side and fix it to the top of wardrobe with hanging hooks.
Do you mean I use the second design for the sides rather than the one in the first photo?
Another question which I have to ask is where do you get the plans for tried and tested furnitures?
Best regards
