blackrodd":1mam28fi said:
Sploo, the finer teeth saw kerf, mainly for man made materials will probably be less than a rip saw, though, much depends on the maker and price.
As I'm just starting out with a table saw, I'd bought blades from Axminster. All the 205mm blades have a 2.2mm kerf (
http://www.axminster.co.uk/axcaliber-co ... saw-blades). I've got a 32T "general purpose" blade with the saw, and added a 24T rip and 48T cross cut (though haven't used either yet).
One of the reasons I've got the TS is for cleaner cuts (vs the bandsaw), so getting the "right" blade for the job does matter to me. I'm assuming it's pretty much always a bad idea to use a blade with a high number of teeth for ripping, even though the finish is claimed to be better? I've not got the 64T "extra fine" blade, but I assume that would be for cross cutting like the 48T?
I get the impression that this size of blade is mostly used in budget machines; hence most of the available blades are more toward the budget cost/spec end of the range - though there are a few Freud Pro blades that might fit (between 180mm and 216mm diameter), but I don't know if they'd be significantly better than the Axy contract blades.
Out of interest; what blade should I use for ripping MDF? Or ply? High tooth count for a clean cut, or low tooth count to clear saw dust? Or is the answer "either; it depends on whether you want fast and messy or slow and clean"?
Can't you use one of the riving knives you already have and just bolt the guard to the top of that and adjust the saw clearance?
Yes, the saw will perform best when the saw blade gullet just clears the stock, and the most teeth are cutting, many saws instructions will advise this. but if you're guard is in place, should be difficult to see.
The knife has a long slot in the bottom, to slide over two bolts under the table surface, so you can adjust the height. Obviously however, there's a limited range of heights you can use, as you want the curve on the knife to match the curve on the blade.
There's a hole drilled into the top/rear area of the knife, through which the blade guard is bolted. The issue is that the height of the guard prevents a full depth cut. You'd either need to fashion new knife that had more material at the top (to get the guard bolt hole higher), or lift the standard knife up (but then the knife curve wouldn't match the blade and you'd have a big gap).
The fence should should lead, as in, head in the direction of the saw blade, just enough to keep the saw effectively cutting a straight line, possibly in the same token as the to-in of a car's steering.
when you can cut a piece of timber,parallel, without any back sawing at the riving knife, and no gap at the fence, That's it! Regards Rodders
I'm struggling with that idea. I understand that if the fence stops at the blade's leading edge then there's no way material could be pinched between the blade and fence, but everything I've ever read about table saws has indicated that getting the fence perfectly parallel to the saw blade is an absolutely critical part of the safety setup of a saw.
Maybe I'm worrying too much about the short fence. I've got it in my head that sheet material may twist towards the fence (specifically towards the non-existent fence at the blade, because it's not being supported). I guess that once some material has passed through the blade, then even the trailing edge shouldn't start to twist, at the rest of the material will be on either side of the blade. Guess I just need to try a few more ripping cuts of sheets.
