Inspector
Nyuck, Nyuck, Nyuck!
- Joined
- 18 Jun 2006
- Messages
- 4,642
- Reaction score
- 2,786
- Location
- Saskatoon, SK., Canada. Elbows Up!!!
Spectric I understand how those rollers work, feather boards too for that matter but would feather board fingers cut on an angle help with keeping the wood against the fence? In other words the saw cuts instead of being square to the faces were on an angle like this ////////// rather than ||||||||||||. The notion only just occurred to me so I have never tried it.
Grandalfs Staff.
While a lot can be done with a dado stack in a table saw you should understand that they cut a massive amount of wood (two blades and however many chippers you are using) they have the power to grab the control from you and either violently hit you or drag your hands into it. It isn't a tool a beginner should use without supervision and instruction. It has the power to overcome the control of the best push sticks too so before using a dado set you should gain more experience and education with your table saw before buying a set. This comes from someone that has them and learned from a very experienced user, my Danish trained father. They are capable of doing great work but it takes more than a healthy respect to use them safely. Get the saw so you have the capability down the road when you have gained the knowledge.
Grandalfs Staff.
