Shultzy
Paul, route out between the holes and nobody will notice
Shultzy":9ohqpv7z said:Paul, route out between the holes and nobody will notice![]()
Paul,Mighty_Genghis":10cptfpt said:Frugal,
It isn't in their catologue but if you ring them they will know what you are talking about (its what I did). On their receipt its down as 'Router Aluminium Table Insert *OFFER PRICE* £29.50 plus vat (305x230x9.5)' but no part number
paul
Feels excellent, in spite of the minor b@lls up ! I'm probably going to leave the holes as they are, eventually just replacing the two pieces with a couple of off-cuts.motownmartin":39z3wt9i said:Nioce one paul, doesn't it feel good when you have made your own kit.
lemonjeff":39z3wt9i said:Paul,
What size is the insert hole please?
Where could I source some laminate from ? I keep seeing it mentioned on the forum but haven't got a clue where to get it fromOPJ":39z3wt9i said:Will you be covering those in a laminate at some point as well?
OPJ":37vzw1vd said:Do you not have any offcuts left over from the fireback you used for the top? That's the kind of stuff I was thinking of.
lemonjeff":z65rd56i said:Paul,Mighty_Genghis":z65rd56i said:Frugal,
paul
Jeff.
might be just the job, i've just found a local plastics supplier so am going to try them first (always good to see something before buying it)OPJ":jd37u5te said:Paul, do you reckon 1mm thick acrylic might do the job?
Just noticed there's a guy in the General Woodworking forum who's looking to do a router table of his own and has found some very cheap acrylic.
