Table saw / Router table WIP - Finished
LarryS.
20 Nov 2007
Hi all,
Following on from my previous threads asking for advice I started building the table this weekend. So attached are some pics to show progress so far....
the starting point, a table saw with loads of bits jutting out which was just too big for the workshop, so I decided to build something with more flexibility so including a router table, storage, drawers and removable jigs / extensions
castors bought from axminster which should keep the unit mobile (very important in my small shop)
the castors mounted on the base
my first ever go with a router !! making a slot for the centre panel to fit into :
made a couple of jigs to ensure everything stays in line:
unit starts going together :
put in a couple of support cross members which the router table will sit on:
the eagle has landed ! :
should be able to use the table rails over the router table section :
router top not cut yet but you get the idea (its a kitchen counter offcut bought from local b&q yesterday for 6 quid) :
left-over bits that I am going to replace with jigs which should take up a lot less space in the workshop:
whats going into the unit :
QUESTION : Where should I mount the router in the router section, in the middle, front left, back right ? My guess is back left so there is max space in front for wide stock and max space to the right for long stock ?
Very nice Paul, and quite ingenious, I'm watching this thread very carefully, if you can do it with your TS200 then so can I, it's just having the guts to do it, if I could do what your doing it would give me at least another 1.5 m square in the w/s, but that will soon get filled, hopefully, with a mini centre lathe, I wait with baited breath.
regards, Rich.
Hi
Nice job,
Where ever you put it will be wrong, so how about you make the top that holds the router removable. And set the router 2/3rds 1/3 off centre and that way you will be given more choice. And as you can get to all sides of your bench well the sky is the limit, you just after make sure the fence can be moved around.
Alan
Bespoke":2iu4ca91 said:
Hi
Nice job,
Alan
fair point alan i might just do that, thanks again for the input
rich,
the planning took a while but actually doing the job hasn't been very difficult, if you want to do it then I'd say have a go, i can send you measurements and more pics if you want
paul
Paul
I think what you are doing is a good idea, it ceretainly saves space in the WS, it also gives you some added space to the right of the saw blades.
Regarding the setting of the router insert, I'd set it back as far as you can, beatring in mind the fence arrangement. Mine I think is set back about 16" (independent router table), and I've managed to put some fairly wide pieces through.
Waka":g6avevms said:
Paul
cheers waka, thanks for the advice
Paul,
Definitely a space saver for you.
Looking at the pix of your shop. I'd also offer the comment that you would find a bunch of drawers will save a lot of space. They are far more efficient than shelves for most things and keep the dust off stuff to boot.
waterhead37":2u8k40n3 said:
Paul,
Chris,
Exactly the same as I've been thinking :D , just going on screwfix to look for the hardware
paul
waterhead37":1kbucezw said:
Paul,
Whilst your on side issues, I would recommend that you plasterboard the ceiling as not only is the dust from the isulation bad but it will also hold any dust you create only to be released into your face when manoevering long stock.
The 1/3 and 2/3 idea sounds really good to me. Good luck with your projct.
Oryxdesign":m9uew0ma said:
waterhead37":m9uew0ma said:
Paul,
cheers oryx, i'm planning to put plywood up there (one of the first jobs with my new set-up !) so that I can hang stuff from it
An update on progress tonight :
wanted to get rid of the mess of pipework :
so knocked up a bit of integration into the unit:
Spot the flaw though !!! Went to cut a panel on top of the saw and realised the top pipe was too short !LOL!, will put the longer piece back on tomorrow
did a rough cut on the router top (will do a clean cut tomorrow) :
I've found that the cheap top is slightly cupped (about 2 mill in the middle) so am going to have to come up with some way to straighten it, live with the problem or buy another top - any suggestions ?
bonus of the day a new present turned up from e-bay :
hopefully some more progress during the week
Paul,
You could flatten the top using the router with a sled accross the top, I remember a post somewhere on the forum on how to do this.
staffie":180yx4cq said:
Paul,
Staffie,
The top is a cheap kitchen worksurface rather than solid wood, as such the laminated top is only about a mill thick (looks more expensive in the photo than in real life :D )
thanks anyway, paul
I'm not sure what to suggest with regards to keeping the router table top flat. How are you planning to fit it to the rest of the carcase? Perhaps... Adding three rails across the shortest distance on the underside and screwing up through the rails would work? I'm not sure, it looks quite thick.
I'm really impressed with how well this is coming along. It makes me think I could squeeze one of those Record saws in my garage-'shop somewhere but, I might have to settle for utilising my mitre saw in something similar.
Are you also planning add a hinged outfeed extension table to the back of the saw?
You might want to play around and find the best position for the extraction hose (crown guard). As it looks currently, it looks as if it might foul any timber or sheets going through.
With regards to positioning the router, look at a spindle moulder for a decent idea of how to off-centre it.
Olly,
I haven't had any flashes of inspiration either, may have to go for a double-thick MDF top and then try and find something to laminate it with (perhaps buy some of that fireback from B&Q that has been mentioned).
The next project is to build a similar contraption for my mitre saw which is currently in the garage because its stand takes up so much space (I want everything I need in the one place). Happy to share ideas on this too if you want.
Yes the plan is to add extensions to both the back and left hand side (hinged and folding down) but haven't worked out the detail yet (the project is now into the 'make it up as I go' phase !
Yup, yet another area where I am waiting for divine inspiration
sounds like a good idea
cheers
paul
Looking foreward to the next installment as this is giving me a few ideas for my set up.
Thanks, Steve.
Not much progress on the project due to family house moves, work, golf and also a bit of my job !
Have decided to make the router table top first, install it then make the drawers using the router table. Attached are some pictures of its construction :
two layers of MDF chosen for the top
Piece of 'fireback' bought from Homebase for £30 to cover the top and bottom (its perfectly flat, shiny and hard-wearing so should be ideal, idea stolen from a previous poster on the forum) :
Warning ! First time I glued it on I copied another post on the forum who had used PVA (but not with fireback like I was using), left it like this for 2 days :
only to take all the stuff off and find that only a light touch peeled the covering off !! Went into emergency cheesed off mode and applied a lot of impact adhesive to both the fireback and the top of the MDF and stuck it all together, 24 hours later it seem stuck fast, learning point there.
Tonight for the first time I used a router with a laminate trimmer bit to trim the edge of the fireback (i'd left it over hanging) and here is the result :
also took a present i'd received of a mini router table from Lidl, took the NVR switch from it and mounted to the table, should make turning the router off and on much easier and safer :
here is how the project looks at the moment, please ignore all the cr*p within the unit :
well chuffed with that. Next jobs are :
Mount the top permanently
Put router plate in it (intending to go for the tilgear aluminium one which I am going to order tomorrow)
Then mount a mitre slot and fence
nice one Paul, i'm still looking and learning,
regards, Rich.
I always knew there was a use for those LIDL tools :D
Keep up the Good Work
Harry
