Bodgers
Bit of an older thread, but how did this look in the end? Are you happy with it?Jona":fhbe419o said:I've taken off the fence rails and extension tables, and loosened the table mounting bolts, now it will sit in my workshop until Monday morning when I'll check if it has moved at all. I'm not expecting much to happen but it's relatively little effort; and who knows how long it's been sat fully locked to the chassis since it came off the line?
Thanks again for all advice.
Lons":fhbe419o said:Jona":fhbe419o said:These comments broadly confirm my thoughts. Most likely I'll set it up as well as I can as-is and get some proper use out of it to see if any genuine problems emerge, or indeed if the step continues to bother me. If so I'll have a go at sanding the whole top with a good flat plate.
Before you start down the abrasive route you should be aware that it's bloody hard slow work
Sent from my MI 3W using Tapatalk
