Hi,
Not sure how relevant the accuracy argument is because if you only need (or only have room) for a 10" table saw then you will be able to buy one that is accurate enough (and there are loads of threads on which is the best table saw).
So it seems to me the question you should ask yourself is whether or not you will regularly need to rip 4" timber (which a 12 saw will do) or will a 3" depth of cut do (which a 10" saw will do).
I am a hobbiest with a small celar workshop and I can make anything I want with an 8" table saw, an 8" depth of cut bandsaw and a 10" planer thicknesser. Have to work round things sometimes, like cutting 4" square legs slightly oversize with the bandsaw then running them through the planner thicknesser to square them up, but it's a hobby and I don't need the speed required in a professional shop.
Just my 2 p's worth.
