I am in the process of getting the 10" Axminster table saw when it comes back in stock. I also ordered and have just received an 80T extra fine blade which I was thinking of using to cut the rebate for aquamac seals for window frames. I am a novice woodworker and have just noticed that on the blade's box it says that under no circumstances should the blade be used to cut along the grain.
Please could someone kindly explain why this is and secondly am I safe to use the blade to make just the fairly shallow cuts to fit the aquamac seal in or should I try and return the blade to Axminster and use a router to do the job.
Many thanks
Many thanks
