I am in a bit of a quandry with my TS-200 and was hoping someone more experienced in such matters might help put me straight. I bought it used some time ago with a particular job in mind but unfortunately have only been able to fiddle with it on occasion. I gave it a bit of a service, cleaning, lubricating etc and then set about resetting everything. Being a fussy b*gger I noticed that the table was out of alignment with the body so sorted that out. I then carried out a few of the usual mods i.e. elongating the little slot for the rise and fall mechanism so that at the lowest setting the blade carriage had a nice positive stop. After that I made a wheeled base and of course the obligatory dust hopper including modified lower blade guard, magnetic back blanking panel and a slightly modified version of the perspex front banana slot cover as kindly provided on this forum. Following all that I bought two new Freud blades and set about aligning the mitre slot to the blade. I found that with such a small diameter blade it would be very useful to get the dial gauge as close to the table surface as possible so I made an oak runner, attached an aluminium plate and drilled it to suit the screw pattern on the dial gauge once the bulky back cover was removed. I wound the blade up to full height so as to have the maximum length with which to work accurately and managed to get it as close to spot on as makes no difference (about 0.005mm). Pleased as punch, I fitted the rails, adjusted the crude fence (I see now why it is unloved) and set up the sliding table for maximum travel in front of the blade which itself I managed to get down to a decent accuracy of 0.02mm.
Happiness is a fleeting thing though, isn't it? I did something I foolishly hadn't considered before; I lowered the blade somewhat and took a reading. I lowered it again and so on until the blade was so low and so short in length that no further readings were useful. It would appear that as my blade goes down, it increasingly shifts over to the left, veering over more so at the rear (roughly twice as much as the front). Once at the lowest point I can get a reading at, there is a difference of 0.5mm between the front of the blade at full height and the back of the blade at lowest. It is worth pointing out that at this low height, the available length of measurable blade is very little thus the difference across the full blade were I able to measure it, would be quite a bit more. I should say also that the deviation is consistent in that once returned to full height, the needle returns to zero or thereabouts. The reason I first noticed something was wrong was when making a zero clearance insert, the blade when being lowered back down, was now widening the slot it had just cut. Wondering if there was possibly an issue with the angle mechanism which was affecting the blade as it went down, I attached my Wixey bevel gauge which showed absolutely no change whatsoever thus ruling that out as the source.
Would you consider this an issue or am I being too particular with it? It is my first table saw so I am uncertain as to what is acceptable and what is not but am mindful that I do prefer things that can be quantified and are dependable. Would a complete new saw carriage fix the problem or is it as I suspect down to the fact that the whole mechanism pivots on what is in actual fact a very small pin and is consequently bound to be less than perfect, not to mention the potential effects of several years wear and tear to boot? I would be most grateful if anyone who has done a similar test would post their findings because at this moment in time I am really leaning towards selling it on and looking out for something better.
Thanks,
Michael
Thanks,
Michael
