Table saw advice?
Yes, a fence like that is wrong, as it is on my SCM delivered yesterday!
Sedgwick- on my one the fence is only held at the near end and can be slid back to the correct length, as you said that’s invaluable when crosscutting.
A short fence isn’t a problem at all, simply keep holding the wood to be cut against it and after the cut the wood can twist and move all it wants. Much better than the wood flying back at you.
Ian
If your machine is a combi the long fence is for the planer but is also handy on a panel saw. You can add a short false fence to it as necessary, or buy a separate short fence which will also be adjustable. The long fence would be adjustable too but you wouldn't want half of it sticking out frontwards.
The long fence on many machines may need steadying at the far end - I Gclamp on a scrap of wood.
Ps I'll pm you my delivery address, can you put a steel framed building on the same lorry? Cheers!!
Edited my post "It's a small panel but big general purpose saw"
Says so in the blurb; 1600mm, not 2400 as per common panel size.
It weighs about twice as much with twice the motor power of my Minimax Lab300 which is a good sized combi but not much of a panel saw at all!
For the record the Laguna tilts to the left, that was a big reason I bought one, the Kity 419 (right tilt) is a cracking little saw but with the add on sliding carriage makes it a very versatile but still a little saw, (mine actually sit's under the outfeed table of my Laguna saw)
One thought I had, @steve355 with your situation, is to possibly think about a vertical carrier to run along your fence, you could work out a method of clamping your stock to it and push the whole jig along the fence, its a solution I use for cutting angles up to 45 degrees.
If I get to the W shop tomorrow I'll take some piccy's of both saws and the jig I use.
Ian
I'm not sure what you are describing as being wrong. The adjustable rip fence on every SCM (also Altendorf and Martin) sliding saw I have used or seen is adjusted so the outfeed side of the fence is on an imaginary 45-degree line that starts at the saw blade arbor and extends to follow the width of the material being ripped. Here are screen shots from the Operator's Manual for my SCM SC2C showing the setting of the rip fence.
I have worked in and visited dozens of German production houses using large format sliding saws. Without exception, the rip fence is set according to the Owner's Manual when used as the only reference. When the material is referenced on the sliding bed and the rip fence is used as a stop block, the shops use a cut-down section of fence that ends well before the cutting edge of the blade.
For me, the rip fence is now a moot point. Since making the positioner for use on the sliding bed over three years ago, I have not used the rip fence.
Well thanks for all the suggestions but I think for now I’ve talked myself out of changing it, for a while anyway.
I’ve improved the vibration a lot, sorted out a lot of the backlash, and found ways to get around the tilting table challenges more safely. I’ve ordered some lovely BSW set screws to secure the fence guide rail better. I found a nice sharp rip blade in the pile of vintage blades that came with it which is giving a better finish.
When the weather improves I can weld up a stand for it that would have a low shelf below for my thicknesser (I’m a hand tool enthusiast you see) for ballast and get some anti vibration levelling feet.
That's probably not a bad conclusion to reach. Your saw looks like a basically decent bit of kit.
If the blade runs true (no wobble) and is parallel to the slot in the table, the other issues can be sorted.
As you can weld, it will be fairly simple to replace the rail that the fence runs on with something that doesn't deflect - even weld an 'L' angle to the underside, turned in towards the saw to add rigidity to the existing rail. Better still, fabricate a Biesemeyer style fence, similar to the diy in the link I included earlier.
While I now have a SIP 01332 table saw, I have also held onto my previous, smaller portable saw and with various tweaks (including a decent blade) it remains a very useful, if basic tool. For all it's worth there was no point in selling it.
I actually wrestled with the question of whether to seriously upgrade it and build it into a stable bench, add a really good fence etc. This would have had a cost, lost the portability and have been a compromise at best. Luckily the SIP cropped up, very nearly new and at £500, so I bought that. My point, if there is one, upgrade, tweak, tune-up for sure but don't overspend. Just also keep an eye out for a suitable table saw at a good price - maybe a nice, old Startrite??
Wood is good. I made this heavy little table for my pillar drill, firmly bolted on.
Transformative - very solid/steady, quieter running etc.
I'd do same for your saw, slightly bigger than the saw-table itself, heavy timbers etc
Not a bad idea, wood is a lot cheaper than angle iron, and arguably has dampening properties. Typically I’ve made them from steel, very solid, very heavy.
The crazy thing is the amount of angle iron it takes. 6 x width + 6 x length + 4 x height. Add the steel shelves and it weighs a lot.
My current table saw stand is wood, but the problem is mainly the small footprint and high centre of gravity, I think.
I think, on balance, my fence is robust. It’s a chunk of cast iron. It’s the rail that’s the problem. If (only if) I extend the fence, and I think I have to, the lever arm on the longer fence is enough to slightly distort the guide rail - only by a tiny amount, but if the fence is longer it can move by a couple of mm at its extremity.
The guide rail has 2 set screws. If I add a 3rd, just before the ruler starts on the pic below, I think it will strengthen it enough so it can’t flex. I reckon that will do the trick.
You're on the right track considering welding.
Anything else shouldn't be considered for that tilting table machine really,
as tilting the machine in order to keep the table flat for those cuts is the safest bet,
whilst also welding up something like in Steve Maskery's new video for those dangerous cutsin which you need a full length fence and Shaw guards, like you've seen in Roy Sutton's videos. It's a wonder you haven't found that out already.
Lookin to loose your fingers with such disinterest, and frankly surprised you haven't been warned already.
Sad that most of the above posters have felt the need to leave,
Can't say I blame them though.
Hope that helps some of ye, as you can see, it takes quite a bit of study if you wish to be safe.
Two push sticks on their own, ain't gonna cut the mustard everytime.
Really raising the bar there with that particular operation/machine.
Over and out.
@steve355 I mentioned the carrier I use to run along my TS fence, some pictures attached that may explain more clearly:
I misinformed you as well, the little Kity 419 tilts left!, but is very compact, couple of pictures of my set up, showing the size difference between the Laguna and the Kity, and in each case the fence can go either side of the blade.
That looks suspiciously like an old 'Royal' saw bench. I have one languishing in the corner of my workshop, which I use as a stand for my bandsaw. I believe that at one time it was sold under both the Tysack and Parry labels.
Mine is the slightly later, floor standing model, though the top was fabricated from sheet steel rather than cast. There was an additional refinement to the fence to stop it moving, which was a threaded rod that passed along the inside of the fence and engaged with a rectangular section of chromed steel at the back . This gripped the back of the saw table when a knurled knob was turned at the front of the fence. This didn't cure the problem entirely as I believe most of the problem in this regard stems from the flimsy chromed bar that the fence runs along..
I had to change the bearings at some stage, and remember being really surprised that they fitted inside what appeared to be a section of steel gas barrel.
There wasn't a sliding table that went with this particular saw, though I did manage to adapt a sliding table from an Elektra Beckum site saw, which worked well enough, for a while.
Niall
Hi. I have a Sundial - Royal -10 inch table saw made by Parry and Son. Does anyone know the age of these machines and what rpm they were designed to run at? Thanks
Hi there, Den,
I had my Royal saw bench from new, purchased from Tyzack's in Shoreditch in the late '70's early '80's. It is the pressed steel version with a welded steel bench top. However, they were still advertising Parry's old and rather quaint, bench top, version, in the Woodworker magazine around this same period.
I will check the motor and pulley ratio on mine when I pop out to the workshop later on.
Niall
Hi there, Den,
Niall
Thanks Niall that would be great as I'm doing a refurb as the bearings were needing done. The saw has been lying unused for a while so I thought I'd tune it up. Got it second hand and don't know about the pulleys but it didn't have the original motor so any help on that would be appreciated.
Just got to look at the motor plate today, as I had to pull things about in the workshop to get a clear view of it.
It is a Brooks Compton one, 2800 rpm and 6.2 amps. It has a double pulley on the shaft and the motor, so uses twin V belts. The diameter of both pulleys is the same, so there will be no difference to the rpm of the blade.
Hope this helps.
Niall
