Hi, Martin
I have not really had much time to use the saw yet, but I have assembled it and made 30 cuts or so. Consider this and the fact that it's my first tablesaw when you read me response.
I'm very happy with the saw. From a performance point of view, I can't
fault it, and I'm very happy. I got the sliding carriage which I assembled this weekend, but did not have the space to try out because of the junk in the garage. (But spent the rest of the weekend clearing it out, so tonight I should be able to try it out.)
From a size point of view, I chose this saw for the same reason you are - space. I ordered the hinged side extension so I can keep it down most of the time. IMO it's also a good balance between weight and portability - got the wheel kit and can drag it out the garage door if I want to cut up sheets.
So yes I'd recommend it on the little experiance I have had so far.
Just one thing - the throat plate is made of thinish aluminium and runs the length of the table. A spring lifts it up against a screw for easy removal. The plate seems to bend slightly. I don't know if this affects the saw's performance, but I thought I'd mention it.
Otherwise a great saw which I would recommend.
